finally dynoed after several months
daniel240
Car: cars/motocross
i finished my kat this winter and i finally got it dynoed today. those that dont remember i have a t3/t04e turbo smic custom manifold, ic piping, exhaust. im running 370cc injectors with the hacked mafs and an msd btm. ive been running a 2.6" id pipe for the mafs which is too small but i did it to be safe till i got it dynoed. i only made 179hp and 197ft/lbs torque @ 8psi. however i was running very rich the entire time around 10:1. i also had my timing retarded quit a bit. i only made 1 run to get an idea of what im running. so im going to go with a 2.75"id pipe for the mafs and dyno again this weekend. btw im using a blow through type mafs. i know these numbers are very low but im hoping it is due to running rich. i want to be in the 230-240 hp range.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
its time to invest in fuel management...
Structure240sx
how much retard are you running?
daniel240
Car: cars/motocross
im using the msd btm and i had it set to retard approx. .75deg/psi. one of the guys dynoing my car said i could have advanced it a little. im just worried about the low hp numbers. i know i was rich and all but would running that rich cause it to be that low hp? im going to try again next week with a larger diameter mafs. i will try to post up the dyno graph.
Structure240sx
thats really about how much you want to retard. is your base timing set correctly? if you are in the lower 10:1 afr's it will kill your power
Projex240
Car: Dogs , My RIDE
afc should be an easy fix for the fuel--the timing would rob a little bit if not set at correct base timing, but not as much as running low 10's afr
Checkered-Member
daniel240 wrote:im using the msd btm and i had it set to retard approx. .75deg/psi. one of the guys dynoing my car said i could have advanced it a little. im just worried about the low hp numbers. i know i was rich and all but would running that rich cause it to be that low hp? im going to try again next week with a larger diameter mafs. i will try to post up the dyno graph.
Does the BTM have a .75 per psi setting? I only saw them come with 0, 1, 2, 3 retard per PSI...anyway...
A good retardation is .5 degrease per PSI, and I think the BTM only comes with 1 per psi…which means you retarded you timing by 8 deg. which is too much IMO
The 10:1 A/F ration is very rich and you lost power there, a good ratio will be high 12’s low 13’s
The HP vs. TQ numbers are right on the money, you have between 7-12% more torque then HP, and it will always be that way until you start hitting 400+HP
Real examples of what some people make: 288rwhp 323tq 226 whp 235tq200rwhp 224tq 220rwhp 251tq238whp 270tq
they all have around 10% more tq then hp...and so do you.
lastly: what spark plugs? gap?
WDRacing
For a daily you really don't want to go any leaner then 12/1. Especially with just a side mount and the only tuning being a hacked maf.
To much timing retard will definitly make you lose power. Set it to .5 after you lean it out and see how she runs.
WD
Structure240sx
its has been discussed in other threads that proper retard for a ka should be around .875 degrees per psi. this is since the NA ecu sees a richer condition it will then advnace the timing some.
your looking to be around low 12's tops. i keep mine in the mid 11's and feel no difference in power
daniel240
Car: cars/motocross
the msd btm is a dial control you can adjust it anywhere between 0 and 3. i had it somewhere in between .5 and .75 so that should be ok. i am using the ngk bkr6e11's gapped at .35. im running 93 octane gas. i ordered a 2.75"ID pipe for my mafs and when it comes in im going to dyno again. im also going to try using it as a blow through type and a pull through type mafs and see if they are the same. but yea my A/F was around 10 the whole time.
daniel240
Car: cars/motocross
and one more thing i just thought of. right before i dynoed i redid my intake pipe. i havent had time to run the crankcase breather hose back into the intake so i just left the hose out. i also just unplugged the ait sensor that i had in the intake. i didnt think this would matter but just want to make sure.
WDRacing
The ecu needs the intake air temp, and you shouldn't vent the crancase into your intake. Your only ingesting oil fumes and effectivly lowering your octane level. Hook it to a catch can.
WD
daniel240
Car: cars/motocross
ok i wont hook back up the crankcase breather hose.
Nathan
Just run the crankcase breather hose out the wheel well (behind the tire) and zip tie it...no more worries :)
daniel240
Car: cars/motocross
yea thats kind of what i did with the breather hose.
last night i found out that the wideband that the shop used when dynoing my car is off and is reading lean. so that means that i am running even richer than 10's, probably somewhere in the 9's or even 8's. so i guess im going to have to wait until they get it fixed to go back.
Structure240sx
yea running in 10's kills enough power for a noticeable difference. in the 9's its really bad
daniel240
Car: cars/motocross
yea i also thought that it could be washing the oil off the cylinder walls too.
