DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Aug 25, 2002 11:39 am
Good job! That didn't take too long, even with the broken pins. The brake job is pretty quick--for less than you would pay a shop, you can buy some speedbleeders off their website. There's also bleeders from Earl's Performance Plumbing, which is actually not too far from where I live. They were about $12/pair. Replace the factory fittings with the bleeders, then every time you need to bleed the brakes, pull the tire, loosen the fitting, and pump the pedal until the reservoir is almost empty and/or the exiting fluid is nice and clear. Takes about 1/2 hour to do all 4 lines, and less than a quart of fluid.
