Had to stop because we were out of fuel, but happy with the numbers and probably wont bother with bigger injectors this year.
Rb25 bottom end rb26 Head
6766 turbo
ported head
260 Tomei cams
thanks for the info, the meth setup should be just fine plus i have a fail safe setup on it so if the meth injection fails or low fluid it will turn off my boost controller and just run on wg spring pressure. But I am debating on e85, but i want to see what I can make out of the pump and meth setup first since im kinda tapped on car funds at the moment because of the body and paint im getting done at the moment. what fuel psi are you running for your e85 setup since we have identical fuel set ups.RRRRB wrote:Idle is pretty much like stock, maybe a little lope/chop at times but very mild.
I'm using Iridium 8's gapped at .025 with Splitfire coils, id be careful with Meth as even cylinder distribution can be tricky with ITB's or just being an inline 6 in general. should be able to make 550-600whp on just pump.
I went to the track a few times last year, thats kinda how the car got where its at, beings i broke 2 rear ends and 3 axles i have upgraded to an R230 rear end and R32 GTR axles.
I will probably see the track in the next couple months when the weather gets a little better, hopefully it all holds together haha be interesting to see how the transmission tolerates this new power.
Injector Dynamics are known for having great idle capabilities with large cc injectors so thats why i bought em.RRRRB wrote:60 psi base 1:1 rise with boost so 90 total
You said you have 2000cc I'm running 1200
You should be fine.
I had 2000cc injectors and I had a hard time getting them to cruise at a reasonable AFR on pump gas, so I down graded.
Thats what i had, and i wasn't satisfied in the slightest, with part throttle/cruise driveability.HxC_Nismo wrote:Injector Dynamics are known for having great idle capabilities with large cc injectors so thats why i bought em.RRRRB wrote:60 psi base 1:1 rise with boost so 90 total
You should be fine.
julio wrote:Looks like that intake mani/single throttle/ported heads combo works well. Holds torque much better than I would have thought for that boost.
