93turbopse »
https://forums.nicoclub.com/93turbopse-u79606.html
Fri May 02, 2008 6:42 pm
I finally finished my TT swap. Two 300zx's, a front clip, a few trips to Noyan, and 1 year later she purrs like a kitten and pulls like a mad man. I started with a '90 2+2 but after I pulled the heart out I found way too much rust for comfort. So I sold it. YES I did fix the rust before selling it but even with my rust cure I wouldn't have felt comfortable with using it for anything else but a daily driver. So I recently bought a 93 that had broke a timing belt for dirt cheap and the rest is history. Two things I love about the swap. I know the most common is 2+2 swap but after owning both, the coupe is hands down the better choice. Less weight, less length, better looks, you cant go wrong. I decided to use the TT ecu with the NA stock harness so I do not have stock control on boost...A greddy profec B spec 2 is in the mix but I am completely drained of funds and then some so I will have to wait. Also I am using the stock cat-back with a HKS hi-per on hold as well.
