steelcity »
https://forums.nicoclub.com/steelcity-u237717.html
Fri Aug 15, 2014 7:29 am
I also forgot to mention that my check engine light came on yesterday.
So this morning I was thinking that maybe it is a vacuum leak from that hose, so I tried getting back there to move the clamp up but I really can't squeeze in there. I felt the hose though. It seems secure. One of the other problems I forgot to mention (duh) is that like an a$s, I never removed those (2) small outer screws on the plenum. The whole time I had (2) remaining new bolts for the plenum and that's when the light bulb hit me. So I removed them today and replaced them with the (2) remaining bolts I had. I obviously didn't torque those (2) down in the order is was recommended. But I did just torque both down to the required specifications. Shouldn't be a problem right?
I started the car and the check engine light was still on. I disconnected the battery and waited about 10 minutes. Connected it back on, started the car and took it for a test drive. Knock on wood, no check engine light and I forgot to mention, the car is not stuttering at the light or when in park. The car does sound like it may still have a small leak somewhere. I am taking it to a mechanic tonight to install my light weight crank pulley and new belts. While I'm there, I will make sure to ask him to double check for an vacuum leak.
Thanks for all your help and concern guys.
