RMiller »
https://forums.nicoclub.com/rmiller-u12169.html
Mon Dec 06, 2004 9:55 pm
The screeching can be intermittent-->definitely loose belts. They shouldn't feel like a guitar string, they should be pretty tight. There should be very little play, like 1/2 inch for a 1/2 foot length. (not sure, but point is it needs to be tight!) Your speedo should work, regardless of year. You might have pulled the plug out while bolting your steering column back in place. I did that with my tach once without realizing it. Wasn't working, so I took it out and I had pulled it out while moving the wires out of the way to make room for a socket extension. KA computer?
Oil leak...tell the shop that put your motor together, hopefully they back up their work.
