USMCgetsome »
https://forums.nicoclub.com/usmcgetsome-u15451.html
Wed Mar 16, 2005 3:56 pm
ok soo i crept through the archives last night and saw projectrb240s post and did some checking so it led me to thinking it was my turbo. Nope.. checked and it's fine. So next i kept lookin and found on the SDU FORUM about bad coil packs. Somehow, they leak and cause grey marks on the braces and rocker covers. Soo i pull all the packs and soo far this is what i've found
1: has no carbon on it what so ever, and i do hear the fuel injector clicking .6ohm on coil pack
2: has no carbon on it either, fuel injector clicking .6ohm on coil pack
3: has carbon build up, hear and feel injector clicking .6ohm on coil pack
4: has carbon build up, hear injector clicking .6ohm on coil pack
5: has carbon build up, hear injector clicking .6ohm on coil pack
6: hsa carbon build up, hear injector clicking .6ohm on coil pack
checked spark plugs and they are NGK BKR6E 11they read 4.53Kohm all 6all regapped to .7mm, before they were close to 1mm or higher
Tomorrow i'm actually going to have someone crank and i'm going to install the coil pack with spark plug and ground to the chasis and watch for spark. Also, I just had the injectors cleaned as well as the fuel rail soo i know for a fact that they are working.
Man i'm soo close to a working 6cylinder instead of a 4cylinder. Hope this helps anyone else with this problem. I'd post up pics but everyone always bit-hes about the pic size. If anyone wants to see what i'm talking about just ask for the pics and i'll be glad to either post or email. look at the braces on the r/h side and look at the black/grey marks.
