Finally a solution for the manual transmission conversion
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
gs14racer
Thanks to me going crazy one day and deciding to do the vh swap, and the fact that a competent machine shop wanted to take on the project. There is finally a solution for all you vh swappers out there for the manual swap
It is designed to work with the vh45 only at this point, but if you want a vh41 it can be done.
Again it is designed to work withTransmission is z32 300zx n/a or ttIt utilizes 300zx clutch300zx flywheel300zx starter
Im in the final test fitting stages of this right now, just making sure the starter meshes up fine (which it should) and what not.
THe plate already bolts the block to the transmission fine.
Heres the link to where anyone can purchase it.
http://www.mazworx.com/store/?...ct=59
Heres a link to all the other adapters they offer.
http://www.mazworx.com/store/?...0Kits
and
Here is there direct link
http://www.mazworx.com/home/index.cfm
For those that dont know mazworx, they are a engine builder, and race car fabricater, and machine shop. They have been in the buisness for a long time and mark (the owner) is a long time racer and stand up guy. I recommend them for any of your custom or engine building needs. Hopefully they can knock out an custom vh engine block with lots of internal goodies.
Also i am not employed or getting anything out of this and i payed full price for my adapter.
Just trying to help the vh community with another option.
Heres pics of it test fitting on my car
Florida240sx
Where you get your z32 5spd at/for? I'm taking my car down south and this is acheaper better route than dixon's set-up. Would be nice to have a 6spd transmission though....
gs14racer
I can to try locate one, my family owns a couple of salvage yards.
Florida240sx
That'd be appreciated.
supermoose
Car: 1995 WRX STi-RA V3+2 V-Limited. 92 Q45 thats getting setup for wangan
hey-
nice work. been following your swap..
do you know anything about compatiblity between Z32 driveshaft and Q45? im guessing that the diff side will bolt up fine, as nissan diffs seem all compatible bolt pattern, but what about imput to trans side and length. if you have a chance, could you measure it?
Return to “VH45DE / VK45DE / VK56DE Forum”
