I'm guessing there's gotta be something funny with your engine. I've seen people make more than that without ITBs and with those mods.PandaS14 wrote:I've got 91 cams in there right now. they helped a lot, but I really need some bigger ones.
Other mods:
Headerhigh flow cat3" exhaustlightweight flywheel
That's it I think.
You really need cams with minimum duration around 268 deg for intake, and 272 for exhaust.PandaS14 wrote:I've got 91 cams in there right now. they helped a lot, but I really need some bigger ones.
Yeah, I dunno. Something seems fishy with the ITB thing. It seems like it should have made quite a large difference (even if not for the better!) but it didn't....it's odd.PandaS14 wrote:I know, I lost no low end power. Everyone with ITB's has been saying they felt like they picked up torque through the whole rpm band, and my dyno is pointing to them being somewhat correct. Every engine is different, as are the setups, but I sure didn't lose any torque, but I sure gained some.
yeah I know the cams I need, I just don't have the $$. I'm still contemplating between drop in jwt cams or going all out with oversized shimless underbuckets, huge lift/duration cams etc.... However, I think my wallet will be making the decision for me...
maybe the stock manifold isnt as much of a hindrance as some people made it out to be? my torque curve improved a good amount with a more aggressive ignition map, so that is probably playing a part as well. its good to see you up and running, whats next?PandaS14 wrote:its not that odd if you think about it. the stock cams can only let x amount of air past the valves. If the stock intake mani is capable of flowing x amount of air or a little more, you won't see any peak hp gain. Hence why my peak numbers aren't above what most ka's without itb's are at. But my torque curve is much improved, as is my top end (lack of significant faloff). So that shows you where the stock manifold can't quite flow enough air for the stock cams.
Ehm. He's trying to flow air at higher RPMs, pistons arent going to change that to any meaningful degree. Replacing his cams should do it theoretically, but I still think something is missing here. Even if we assume the intake manifold was perfectly tuned for the s13 cams, why is there no difference in the car's power when they went to s14 cams with basically the same manifold? Something really isn't adding up about the engine.Thee 240sx Owner wrote:I agree with NISMOFREAK on that.... it is a racing setup but no internal work is done... its like ricers... alot of stuff outside the car but nothing done inside to make it fast... you pretty much have flow of air and exhaust taken care of... now its time to start ripping the block apart and doing internal upgrades starting with pistons first...
