FINALLLLLY finishing my set-up (rims/brakes)
Touge_Drifter
Car: 1995 S14.5
1995 Nissan 240sx SE
2004 350Z
2011 cube
Ordered my Advans (super ver.2) back in oct.12th. The D1GP gunmetal rims are the only other set in the us. I had to BEG Advan to dothat color for me. only japan color! got my 18x9-front w/+15 offset & 18x10-rearw/-8 offset. Before to freak out, I'm running a widebody kit! My new brakes finally came in also. Rotora 6piston front calipers w/15inch slotted rotors & 4piston rear calipers w/14inch rotors!
The rims are going to be in the us on Feb.22nd & I'll post pics when they are here!
WARNING......Rotors look little on websites!!!
adrianfromthecastle
Car: 1992 Nissan 240sx
wow.
Baller Brakes !!!
hannibal
Car: Red Line to Glenmont
Good grief Charlie Brown!
AirWerks
They should sell these brakes with goggles to keep your eyesballs from becoming projectiles. Holy crap!
nismofly
Car: 89 Nissan 240SX Hatch
Touge_Drifter wrote:got my 18x9-front w/+15 offset & 18x10-rearw/-8 offset. Before to freak out, I'm running a widebody kit!
are you sure thats + and not - in front
because with +15 front you dont need overfenders at all, thats a nice fit on stock fenders, but you will need 30s for the rears...and stock fenders in front with widebody and much wider stance in rear will look awful funny
if it truly is +15, youd better get to more begging to change it to something more like -10, or else youre going to be running 1 inch spacers on each of the front wheels so that itll look right
also, i hope you confirmed that these will clear your brakes first, or youll be running spacers regardless
Touge_Drifter
Car: 1995 S14.5
2004 350Z
2011 cube
I had the brake set-up all measured before the rims were ordered. Everything should fit just fine! The +15 is just what I needed! BUT I guess we'll see
nismofly
thats what im saying, the 10 -8 in the rear is going to NEED over fenders, but if you run them in the front with that size it wont look right, and youre going to end up having stock front fenders and 30mm rear overfenders, itll look funny
Touge_Drifter
Car: 1995 S14.5
2004 350Z
2011 cube
O I C. Still trying to pick out tire size! Getting it ready for Super lap bettle in june 21st-22nd @ mid-ohio. Was going to run BFGoodrich 245/30-f & 285/30-r
one ton garage
Can you take pics in the caliper channel with the pads removed? Just curious how rotora's qc is nowadays...
