cdiver »
https://forums.nicoclub.com/cdiver-u4828.html
Sat Jun 28, 2003 8:15 pm
Ok, I have searched [brake flush] the NICO boards, and I have found scattered parts of information, but I’m a DIY guy that needs things spelled out for him.
1. Is a brake flush a DIY item? (yes, I will use Valvoline SYN) All the cost savings in the world is not worth an accident from brake failure. I have in the past changed pads, on my old van, my not on my Q.
2. Does the car have two be running when I depress the brake pedal to flush/bleed?
3. The service manual on BR-4 specifies a bleed order when flushing the brake system – will this procedure also flush the fluid from my ABS unit?
4. Do I remove all of the fluid from the reservoir tank first with a turkey bester, then refill with the new fluid?
5. Are the “bleeding kits”, which are a plastic hose and cup worth the $ or the time to use them?
6. Someone said in a post to flush the system with water? Can’t I just use the valvoline Syn instead? I’m not comfortable in using water, even if brake fluid is water soluble.
7. I use a flare wrench, right, What size do I use?
8. Is there a check list anywhere or a protocol for flushing the brakes on a Q?
Thanks everyone,
Stephen
