Final results!!!
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
Broken bolt on the idler pulley. Fuq. Anyhow, will post up pics and compression later on tonight.http://videos.streetfire.net/p...DDA15
the video is up and running as of 2/22/06Modified by KUILLIN_DRIFTER at 1:44 AM 2/21/2006
Modified by KUILLIN_DRIFTER at 1:20 PM 2/22/2006
lucky7
Car: 97 RB25 S14
hahaha. that sucks.
Modified by lucky7 at 4:00 PM 2/20/2006
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
a motor is only as strong as it's weakest link :-/
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
How does that bolt see enough stress to break? Isn't that one especially thick to begin with? Weird.
Bronze MFP
if the bearing in the idler died, then it could have put enough stress to shear the bolt off maybe. just a guess. doesn't change anything now though, someone has a lot of work ahead of them
Shocker
Car: 89 240sxHB rb26/30
belt could have been way over tightened also causing stress on it, either way, good luck man, at least you have a fresh motor, and hey, you can part out your old one for some cash too.
USMCgetsome
soo far everything seems fine. I'm going to put on the belt tomorrow and do the compression test and see what happens. Your right about that bolt being heavy duty. I have no idea why it broke off. Maybe vibration. But i took the cam covers off and everything looks fine.
Darius
so the idler broke completely off? wouldn't the timing belt slip/fall off causing "interference" between the pistons and valves?
USMCgetsome
soo i reassembled the belt and the pulleys. And everything rotates. The valves seem bent and venting the compression out. Won't know untill later on today. But besides that seems well. I got a new one coming at the end of the week.
If anyone is intersted it's yours. If anyone wants video of the motor just email me at [email protected]
I hate this damn motor. I've had problems with it since i've had it.
i still had the timing belt covers on and that's what kept the belt on the cam pulley, tensioner pulley, harmonic balancer. The idler pulley still had the bolt in it and was jossling around in the cover making that funky noise.
Bluefire
Hmm... I might be interested in taking the longblock from you depending on how much damage there is and how much your willing to let it go for. Email me at [email protected]
-BLuefire
USMCgetsome
video is up and running.
