think my final list is done. I've pretty much have all the engine components that i need. if you see something that i'm missing then please fell free to add on. I'm hoping to have everything completed by the end of summer. just in time to drive it around a bit before the cold weather hits. looking to get a sponsor maybe to offset most of the cost. everything in italics is what still needs to be purchased. about another 10K in parts. power goals are around 500+whp
Drivetrain:
Nismo Engine/transmission mountsACT Heavy Duty 6puck sprung clutch Torque Capacity: 463 ft/lbs.Nismo steel braided Clutch lineVLSDNismo Slave Cylinder and pivotFidanza lightweight fly wheel/ Fidanza Friction plateOne piece steel drive shaft Stage1 Chromoly Axles (549.99) Kaaz 1.5 way LSD 778.99
Suspension:
Tein super street CoiloverSuspension technique sway barPeak Performance Urethane Subframe BushingsTanabe Sustec Strut Bar front/rearNismo Power Brace S139. Kazama Pillow ball tension rods Kazama Hard inner tie rod Kazama Pillow ball tie rod ends Kazama Front Tension Rods 1200.00 Kazama Rear Upper Control Arms Kazama Rear Traction Links Kazama Rear Toe LinksNagisa Shakitto Shock Tower Plate 240SX '89-'94Tanabe fender brace
Braking Power:
Brembo slotted brake rotors ( Stock 240sx 4 bolt pattern)Hawk break padsAgency Power Stainless Steel Brake Line Kit Stock FrontAgency Power Stainless Steel Brake Line Kit Stock Rear 5. Rotora Rear 2pc 13in Brake Kit 4piston (1,000)4. Rotora Front 2pc 13in Brake Kit 4piston(1795.99)4. DiF Tokico Nissan 300zx Brake Master Cylinder Upgrade (Z32) 279.99
Engine Upgrade:
Top end:
TODA SR20DE(T) Intake camshaft 264/10.5mm TODA SR20DE(T) Exhaust camshaft 264/10.5mm Ferrea Dual Valve Spring Kit for Nissan SR20DET Ferrea Valve seats Ferrea Titanium valve retainers Port Flow Manganese-Bronze Valve Guide Set Brian Crower Exhaust +.5 Valves for SR20DET Brian Crower Intake +.5 Valves for SR20DET ER Spec Stainless Rocker Arm Stoppers Cometic 1.1 87mm metal head gasket, Copper Exhaust gasket, Metal Turbo Gasket, ARP Head studs
Bottom End:
-CP Pistons 86.5mm 9:0:1 compression-Eagle Connecting Rods with ARP hardware.-Main Bearings-Crank Bearings-Thrust Washers
Fuel System:2 Walbro 255 Fuel pumpsTomei 740cc InjectorsZ32 Fuel Filter Nissan SR20DET NGK Iridium Spark Plug Set for Nissan SR20DET Sard Fuel Pressure Regulator hose type fittingLiquid filled Fuel Pressure Gauge
Power Upgrade:Greddy gt2871R turbo Taka S13 SR Bottom mount Turbo Lines:w/Taka Ball Bearing Oil RestrictorGodspeed intercooler w/ custom intercooler pipingHKS ssqv BOV w/ custom pipingGreddy intake plenium (polished)Tomei 3” throttle body (350.00)Snow Performance Stage 2 Methanol KitZex Nitrous system 75-150HP kit w/ led purge system650.00Full race t4 pro race manifoldGarrett 3076 turboTomei exhaust manifold (heat wrapped)Tomei exhaust elbow
Engine Cosmetics:
ATI Super dampener main pulley 400.00Flex-A-Lite model 345 Dual fans Power Enterprise Super V-Belt (Kevlar) S13SR-Belt-Set/Main,P/S,A/CGreddy SR20DET Oil Pan Megan Racing S13 SR20DET Light Weight Pully SetSamco hoses ( radiator, couplers, etc.)Greddy Oil Filter Relocation Kit for Nissan S13 SR20DET MA powersteering custom line (powersteering line)Color BlueMegan Racing 1 3/8 water temp adapter Circuit sports polished coolant tankKoyo RadiatorNISMO SR20DET Grounding kit(4 Gauge)
Interior Upgrade:
2 Sparco evo2 racing seats1300.002 Willans racing harness550.00Chromoly 4 Point Roll Cage Nissan 240SX S13 91-93 (modified harness bar w/ support bars welded on shock tower, and plates welded to floor pan)Roll Bar Padding - SFI Spec 45.1 Rollbar Padding
ATI EZ-Pod : S13 89-94 240SXCarbon Fiber door panelsMomo Stealth foot pedalsMomo Stealth FootrestMomo Aluminum grid floor matMomo Floor matsMomo shift knobMomo leather shiftbootMomo stealth EbrakeMomo Ebrake leather bootMomo steering wheel350.00Work bell quick release adapter450.00Momo Steering Hub90.00
Gauges/Controllers:
Haltech E8 ECU w/ Map sensor Air temp sensor TPS sensorDual stage shift lightCoolant temp sensorGreddy Turbo TimerAEM Uego (Wideband)AEM TRU-BOOST Gauge-Type ControllerSaga Technik Gauges (fuel pres, oil pres, oil temp, water temp, Boost )
Audio:
2 8” Rockford fosgate sub2 10” Rockford Fosgate Sub2 6 1/2 “ Kicker door speakers4 Kicker 100watt dome tweeters1 Rockford fosgate P-400 amp1 Rockford fosgate P-200 ampCustom sub enclosure/ amp rackKenwood deck w/ USB connection
Exterior:
7. S15 OEM Lights 649.95 S15 Radiator core support 255.95 Techone High intensity discharge light kit 235.958. Super Made S15 front bumper 1500.00 Super Made S13 rear bumper Super Made S13 side skirts9. Seibon S15 Carbon fiber hood500.00 AeroCatch Lightweight Hood Pins – Locking100.00 S15 Hood Hinges4. Ichiba Front & Rear 5 Lug Hub Conversion Kit 89-94 S13 240SX (519.95)5. ZE Forge Wheels (19 X 8.5 front 19 X 10 Rear)3000.00Or Fine Forged Progressive TERubber coated Under bodyCustom House of Kolors paint4000.00
