no, upgraded exhausts shouldn't cause any problems unless you break the legal sound limit, which i'm confident is around 90dB.
BlackMamba08 wrote:you won't need to smog your car for a while... just keep the old pipe and re-install it when it comes time.
this. from what i've heard, swapping the y-pipe isn't really all that difficult. also, the y-pipe is only an instant fail
if the inspector looks under your car and sees you installed the y-pipe in lieu of the 3rd cat. if it's only hooked up to the machine and they don't even look under your car, you should be fine.
ugh, try reading what i wrote before!
legend_217 wrote:To be very honest with you. If you want more power than just get a different car like G37 or BMW, etc
they already have the altima coupe, and they might be stuck in a lease agreement or locked into payments. also, not everyone has the money to upgrade on a whim like that.
