LinkNuc »
https://forums.nicoclub.com/linknuc-u77126.html
Thu Sep 10, 2009 12:40 am
Obvisouly you can use the K&N recharge kit (comes with cleaner and oil), just be patient for it dry and be careful not to over oil, I would avoid driinking to much before hand, lol...I fouled my MAF in my 350Z, luckily I was able to use an electronics cleaner on the MAF and then reset the ECU using the gas pedal sequence and it got back to normal.
FYI disconnecting the battery will NOT reset your ECU but it'll mess up your radio stations, you need to so the gas pedal sequence or ODB
Can't remeber but someone did confirm the ECU reset sequence does work with the push button ignition. It usualy took me a couple tries to get the check engine light to start blinking
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON. A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds. 2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds. 2a. Fully depress the accelerator pedal (HARD). 2b. Fully release the accelerator pedal. 3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking. 4. Fully release the accelerator pedal (while the CEL is still blinking) 5. Wait about 10 second. 6. Fully depress the accelerator pedal and keep it for more than 10 seconds. 7. Fully release the accelerator pedal (The CEL light will continue to blink). 8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone. If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Edit: Added the "Easy Method" for ECU Reset
The Easy Method:
After experimenting with different timing, and reading posts by other members, I've come up with a condensed method of doing this reset. This method works EVERY time, even w/o a stopwatch. I've used this method successfully a dozen times, or so, now w/o a watch. After a few times, you won't need a watch or instructions. You'll get so darn good at it, you'll find yourself doing it while waiting at a traffic light.
Timing is not as critical with this method...no stop watch needed. Just count in your head...one-one thousand, two-one thousand, etc, or use stop watch. The most critical step is step #3....wait 10 sec, instead of 7.
1. Ignition "ON", count to 3.2. Depress/Release pedal 5 times...hard and fast.3. Count to 10 (not 7!) and fully depress pedal4. Count to 12 (SES should be blinking), release pedal5. Count to 10, depress pedal6. Count to 10, release pedal.7. Turn off ignition, then start engine. Done!
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released. 2. Turn ignition switch “ON” and wait at least 2 seconds. 3. Turn ignition switch “OFF” wait at least 10 seconds. 4. Turn ignition switch “ON” and wait at least 2 seconds. 5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released. 2. Turn ignition switch is “ON”. 3. Turn ignition switch is “OFF” wait at least 10 seconds. Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
1. Perform “Accelerator Pedal Released Position Learning”. 2. Perform “Throttle Valve Closed Position Learning”. 3. Start engine and warm it up to normal operating temperature. 4. Turn ignition switch “OFF” and wait at least 10 seconds. 5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds. 6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds. 7a. Fully depress the accelerator pedal (HARD) 7b. Fully release the accelerator pedal. 8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON. 9. Fully release the accelerator pedal within 3 seconds after the CEL is ON. 10. Start engine and let it idle. 11. Wait 20 seconds. 12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications
