fleurys »
https://forums.nicoclub.com/fleurys-u158666.html
Tue May 10, 2011 12:25 pm
If I follow your logic, you want to change the filter because of what you have seen on youtube... Then you should also assume that if the filter did not do it's job, then your oil is dirty too.... Then you should change the oil too.... no ?
I have been using fram high mileage filters since the beginning with my truck... If you change at every 5000km, you will be ok... I'm going on 240,000km and the engine is running as new... mind as well change the oil too if you're gonna go through all this trouble anyway for the filter.... my 2cents
