I know there are "myths" about filling the gas tank, but I guess this pattern has become my habit.
I was wondering what do you guys think about all this. Anyone with the same habit.
Waiting for the light to go on is bad, the gas is what cools the fuel pump in the tank. Having 1/4 of a tank or less will hurt the pump, even more so in the summer temps.BlinG* wrote:Same here, i fill it to the top or nothing. I let mine get low on the regular....until the light comes on
I try to avoid letting it get much below 1/8 tank - and prefer to fill it at 1/4 if possible. (Much more rarely, the light comes on.) This is not always possible, of course.DaSerb wrote:So I am not the only one waiting for "E" to light up.
I usually put in 8-10 gallons.
I agree. Plus letting the tank get lower than half aids in building up condensation or water in the tank in the cooler regions. When it gets cold we fill all gas tanks at half full.06M4.5 wrote:I try not to let the gas gauge go under 1/2 tank. I fill it up until the gas handle clicks off the 1st time and thats it. If you fill it up more your just going to mess up the e-vap system.
This would explain that even when I fill up with the light on...I can barely get 18 gallons (and ours is a 20 gallon tank).szh wrote:I try to avoid letting it get much below 1/8 tank - and prefer to fill it at 1/4 if possible. (Much more rarely, the light comes on.) This is not always possible, of course.DaSerb wrote:So I am not the only one waiting for "E" to light up.
So, my typical "fill to the brim" is then about 17 to 18 gallons (very rarely 19) ... leaving a few gallons in the tank to cool the pump.
In 10 years of driving my M, I have run out of gas only once ... due to the faulty fuel gauge problem (fixed under Extended Warranty) giving me a false reading of 1/4 tank.
But, I have to admit that I have never heard of filling it too much as being a problem.![]()
In my 2003 M45, the pump shuts off about 1 to 1.2 gallons prior to a complete full, and I tend to fill it up to the brim - did not know that this was "bad"(?)
My wife's brand-new Acura TSX is much worse in this ... it always seems to shut the pump off anywhere between 3.0 to 3.5 gallons short (which I have checked by continuing to do the fill). Which is silly, IMHO.
Z
