Ever Victorious »
https://forums.nicoclub.com/ever-victorious-u44595.html
Mon Nov 26, 2007 2:03 pm
I've noticed on both of my V's that when you move the key from OFF to ON, after a moment there is a noise of some sort of component being moved in the rear of the vehicle. I wonder, based on your description, if there is a flap that closes over the tank when the car's ignition is ON?
In any case, you are not supposed to fill your tank with the ignition in the ON position. Technically, you're not even supposed to have it in the ACC position because a spark CAN cause ignition of fuel vapors. It's incredibly rare, but it happens even to this day.
