dsmtunr1116 »
https://forums.nicoclub.com/dsmtunr1116-u10881.html
Sun Nov 02, 2003 11:10 am
all you have to do id take out those four bolts and a snap ring, i believe. and then pull the shifter out. after its out all you gotta do is have someone lay under the car,take out the drain plug and watch for it to come out. thats how i did it. just thought it was easier. oh yea, if you dont have any snap ring pliers there is a way around them. take some needle nose and gring off a little of each side and try to fit it in the holes of the snap ring. thats what i did to a cheap pair of needle nose. so instead of buying a tool that i might not need again for a while i just made it. but try not to lose the snap ring. good luck man, if you have any more questions just ask!
