TJcars2 wrote:I just looked up the amount in the fsm and it said 2.1l/2.25qt, I added a little more to be sure.
Justin, that sounds like a pain. Do you have to do that every time?
just make sure the transmission fluid is gl-4, i think that mobil 1 is gl-5 witch is too acidic or something and is bad for the copper syncros in your transmission.TJcars2 wrote:Also, I'm curious on what you run in your transmissions. Right now I have Mobil 1 75w-90 Synthetic in there.
In my diff I'm running 2/3 Royal Purple, 1/3 Mobil 1. Both 75w-90.
