QCtech »
https://forums.nicoclub.com/qctech-u272909.html
Tue Sep 19, 2017 11:09 pm
I see a few problems that have nothing to do with the other. You disconnected your battery for a long time it seems. And you say is idling low.That for me sounds like you need to do a proper idle relearn. If after that it keep giving you problems, then you should check for vacuum leaks and you IAV valve. On the 2003 LE, your IAV is completely electronic, and when they get dirty they start giving idle problems. I had that problem on my 2003, cleaned the IAV properly and carefully and problem gone. You can do the idle relearn with a proper wireless dongle from Ebay and the datascan 2 lite software free from the google app store, or with the data scan2 complete software and cable.(around 70 dollars and still cheaper than the dealer).You can easily measure if the problem you are having is your sender by just measuring with a cheap harbor freight multimeter and following the manual which is on this forum. This measurement you will do with your tank full and after running the equivalent of half a tank and then again when you think your tank is almost empty(about 250 miles on one full tank). The resistance will change and following the provided manual chart, you will know if your sender is ok.The measurement is taken without opening the fuel tank,just under the left passenger seat is the connector to measure it,again, shown in the service manual. If you dont know how to read a multimeter or do the test, pm me and I will give you detailed instructions. This problem for our year path is most of the times the gauges, and you would have to remove the whole unit and replace or send to an ebay repair service that charges around 65 dollars to have it fixed. Since you were playing with the battery cables, I would follow the service manual and find the cables that go to the display and see where they get their ground and check for those grounds to be properly attached. Changing oil and battery cables wont bring any of the problems you mentioned.And I dont think that cataly
tic converter code can do any of this either. Removing the battery for a long time might erase your idle valve relearn. You need to erase all ECU codes before doing the idle valve relearn or it wont take it. Normally the data scan 2 lite software that I mentioned can do all this. Clean carefully your IAV and do a relearn and that should fix your idle issues. Then measure the sender unit to discard sender and pump issues. If you need more info let me know and will try to TBS it with you. Google nissan data scan 2 so you go to their webpage and get the software or the dongle or both. OBDinnovations sell it also at a cheaper price than the data scan webpage.
