elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun Apr 30, 2006 5:12 am
The cars have to be designed to run safely on 87 octane for incompetant owners (demonstrated in the previous owner) and also so the car can be operated in places where premium cannot be found.
The thing is that pump octane rating is so iffy than on an average day the premium on the pump (91-92-93-94 octane) might actually only be like a 89 lab octane... If you knew you were running a TRUE 87 octane you might be able to get away with it in the winter time (below 60F)... above 70 though, all bets are off because it will surely ping.
So i put premium in my Q (even when it was stock) because it is a high compression motor that should run premium. Youll spend an extra $200 per year or so by using premium, no more than a couple dollars per fillup.
So to answer your question... you probably wont feel any adverse effects, but your car surely wil not get as good fuel mileage and run as good as it should.
