Movingviolation240 »
https://forums.nicoclub.com/movingviolation240-u104.html
Sun Sep 14, 2003 5:44 pm
Sounds like a dead coilpack or ignitor chip. It's been a while since I've done this so my instructions are kinda vague..... but here it goes anyhow..... Pull the ignitor out, one side will have 5 pins and the other side 4. the '5th pin' will be a ground that's constinant on the 4 pins on the other side. So take a test light and put it on the 'extra pin' (it's either on the left or the right, try them both to figure out which one works) and then test the ignitor on the other side to make sure they have continuity.
And just to be sure you had it grounded, try swaping that coilpack (the bad one) to another plug and see if it fires over there.
hope that helps a little,
Paul
