Fidanza Resurface
LT_Z
I recently bought a Fidanza aluminum flywheel and it needs to be resurfaced, has anyone done this ? how many times can it be resurfaced ? Im just curious my shop says they have done them im just wanting to know. Is it the same as regualr wheel ?
Nathan
All the fidanza's I've seen have the replaceable friction surface, I'd just get a new one of those.
LT_Z
Every time you change a clutch ? that seems kinda extreme, is that whats suppose to be done ?
Nathan
I dont really know, it probably CAN be resurfaced if it's not badly chewed up. I just plan on always replacing it as I have a feeling pucked clutches will chew it up enough to need replacement. You could always call fidanza and ask them since I dont have a definite answer and it doesn't seem anyone else does either :)
huguetpj
Car: 93 KAT Coupe
LT_Z wrote:Every time you change a clutch ? that seems kinda extreme, is that whats suppose to be done ?
No, not every time you change your clutch. But it can be resurfaced if it's not too badly chewed up.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Just change the friction surface you can do it yourself its madd easy
LT_Z
oK kewl but where can i get one ? I cant find one anywhere
Nathan
You'll have to get it from fidanza most likely. The easiest way is probably to just call them instead of trying e-mail.
Structure240sx
enjuku can get jsut the friction surface for u porlly a lil cheaper than fidanza.
