The GOOD:
1) The engine started up a lot quicker.2) The engine is a lot more responsive and rev happy.3) Car feels a lot lighter.4) Acceleration through the gears seem a lot smoother.5) Everything fitted PERFECTLY. No dremelling, no hammering, or sanding. I guess fidanza fixed the hole-too-smal problems.
Now, the BAD:
1) Clutch pedal effor is a LOT softer than before I changed out everything. I don't know if it's due to the spec clutch, if I did something wrong, or if replacing the stock rubber hose/damper system with a stainless steel line made that big of a difference. I bled the system and adjusted the pedal. No change.
2) Clutch chatters a bit if I drive in 2nd gear at about 3krpm and let off gas. Hopefully it only occurs during break-in period.
Overall, I'm satisfied with this Fidanza + Spec Stage 3 clutch combo. Is it worth it? Yes, if your car is modified. Can it be daily driven? Yup. Was it a pain in the arse to install? Yup, because I never did a clutch swap before!
After 500 miles of break-in, I'll be all
