supreamS14 »
https://forums.nicoclub.com/supreams14-u53500.html
Tue Jun 03, 2008 12:32 pm
Fidanza flywheels are not that good! I will sell you a brand NEW act prolight(9.5lbs.) for $200 shipped! Research flywheels and im sure you will stay away from Fidanza!That steel insert heats up so much it becomes WARPED! bolted on insert has less surface area Pressed on ring gear!
ACT flywheel:
One piece construction allows less opportunity for failure and provides uniform efficient heat transfer from the clutch disc. No more warped inserts or loose ring gears.Integral ring gear permits more weight reduction where it matters most and eliminates the chance of gear breakage or separation from the flywheel.
Modified by supreamS14 at 7:28 PM 6/3/2008
