Fiberglass S13 front end?
prigo
Anyone know if there is one? Thinking of ways to lighten the car, wasnt sure if anyone makes em. Want it S13 style (for my 240sx coupe.)
Just curious, thanks for yer time guys.
Eklectrick
Car: Photography, Computing
do you mean stock? I'm sure you can find plenty of fiberglass bodykits. check the sticky about bodykits lots of links there.
prigo
I want the SILVIA style
Ill check the thread.
yeswepromise
well here is my idea...MSPORTS fiberglass vented hoodMSPORTS fiberglass vented fendersMSPORTS fiberglass front bumper.http://www.autoimaging.com/sho...at=99
Eklectrick
prigo wrote:I want the SILVIA style
well then you'll need the silvia headlights, fenders and hood unless you got them already for some reason. still, I'm sure you can find some fiberglass bodykits for a silvia too.
NeedCAforS13
Car: CA swapped S13 coupe
i've heard you save 30 or 40lbs using the stock silvia front vs. the 240 front...don't know if its true though...
Sean
Infamous
um, he wants the silvia front end in all fiberglass, as i understand....
NeedCAforS13
i know i was just pointing out you save weight with the stock silvia front end anyways... nevermind
d-style makes fiberglass fenders...tons of companies make fiberglass bumpers...get a carbon fiber hood, and run no bumper support and you'll be good to go!
Sean
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
So I'm wonderin--would I use the 180SX Aerokit, or would the S13 kit fit mine (I'm keeping the popups) if I decided to order one (240SX coupe--'93)
Eklectrick
[ZERO-S] wrote:So I'm wonderin--would I use the 180SX Aerokit, or would the S13 kit fit mine (I'm keeping the popups) if I decided to order one (240SX coupe--'93)
Just cuz this always confuses the hell outta me i'm gonna try to clear one thing up. when you refer to an s13 that includes the 180sx, and '89 - '93 240sx hatchback and coupe, and the '89 - '94(?) silvia. I think that by the context of your question you mean the s13 silvia. to answer your question; I think the 180sx front bumper and side skirts would fit the coupe, but I don't know about the rear bumper if they are the same between hatch and coupe. the silvia front bumper alone would not fit with your pop up headlights.
rudee023
Car: '03 Infiniti Q45
sideskirts will fit, but front and rear are not interchangeable on fastbacks and coupes
