I'm doing something similar to this http://web.njit.edu/~cas1383/p...x.htm . I just find it hard to believe that all you need to do to attach the fabric to the fiberglass shell is hot glue or staples?
I have looked in other posts (zerothread?id=52048) and they say the same thing.
Do you have to do anything special once resin drys on the fabric? I'm guessing you will have to lay fiberglass over the the edge to connect the two halves?
