fiberglass ideas
Post all your Nissan electronics, car audio and stereo questions here!
dori240
Car: 2000 ford focus, 92 nissian 240sx
hears one of the speakers i'm putting in the back of my s13hears the rear mounting holes after i enlarged themhears how i was thinking of mounting them
i have all the fiberglass supplys i just need some ideas on how to start this project.i have rings i just need to finish cutting out to screw the speaker on to aswell
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
In the Ultimate Car Audio sticky at the top of this forum zerothread?id=115587 there is a lot of info on fiberglassing things. Don't take my word for it, because I may be wrong, but I think all you need to do is cut a piece of fleece cloth to go under the speaker and form it however you want it. Then you lay your resin and fiberglass, and keep building it up.
I just fiberglassed a dual 10" box I made, and it really wasn't all that hard. It's hella messy, especially when you sand it, but once you start you will catch on fast. If it's possible do it outside of the car because resin STINKS.
Good idea though, Im looking forward to seeing how it turns out.
Simmsled
Car: TSI GTI - E46 325i
oh where is ayjay when you need him?
PoorManQ45
you don't need no stinking ayjay, you got me.
You'll need to mask off the area that you want to fiberglass. By mask off, I mean two layers of masking tape.
Then you do all your fiberglassing right on that. This will give you the back of the mount/enclosure. Once that's dry you can take it out. Then you mount the ring over the fiberglass at the angle that you want it. Then you staple the fleece to the ring. Then you pull it tight and secure it all the way around the mount/enclosure. Then you mix up a large batch of resin/hardner, add about an ounce of acetone to it, then apply it to the fleece. Try to soak it completely. Then let the dry. Then put a few layers of fiberglass on top of that. Use the thumb test to see if it's strong enough. If it flexs very little it's ok, if it flexs alot you need more fiberglass.
dori240
i know how to fiberglass it i just dont know like if i mask it all out and build a box the speaker wont fit. basicly i'm just trying to make a new cover. i know i could srtetch fabric over the ring and like staple it to the trim but then once its hard i dont know how i will perminatly attach the new cover
PoorManQ45
I would say attach it using screws
Does that speaker call for an enclosure, or is it designed to run free-air?
Curious, what size is that? From the pictures it looks like an 8~10in sub with an oversized surround
dori240
i dont know **** about car audio. its a 6" mid-bass speaker. i think it is made to just fit where stockers should be. i dont think i need a full on box for it but i dont think i can just hang if from the roof as well
