Fiberglass Hood for S14
S14aMike
My hood has some scratches on it and since I have to paint it anyways I might as well try and get a fiberglass one while I am at it. I did a Google search but didnt find anything so I was wondering if you guys knew anything? I don't want a carbon fiber hood because I think it looks riced out and I think fiberglass hoods are lighter anyways. A stock looking one would be best but some modest vents might be OK.
Spectre
Car: 1995 Nissan 240SX SE
You might not want to put a fiberglass hood on. Do you really want all that heat under it? I don't like the carbon fiber look myself, but I'm pretty sure that carbon fiber is better at handling heat.
Anyone know if a carbon fiber hood can be painted?
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
CF hoods can be painted, they are lighter than fiberglass, and more rigid. They are also nearly twice as expensive. They get a bad rap as ricey... but they do serve a purpose... just not a very important one.
S14aMike
For some reason I thought you couldnt paint carbon fiber. Is the surface smooth? Are you sure carbon fiber is lighter than fiberglass? There is still the price issue, though.
MaineExport
I believe cf is lighter than fiberglass... almost positive, but I've been wrong before! ;) It can easily be painted... even if is has a smoothed surface.. a quick scuff sand and primer job will take care of that. It is more expensive, and like I said it has benefits over fiberglass.... WAY more rigid.
Daunttless
CF IS lighter than fiberglass.
Stock hood is like 47 pounds.
Fiberglass is like 24.
Carbon Fiber is like 16 if I remember correctly.
Carbon Fiber can be painted.
Fiberglass can be painted.
Fiberglass will hold up just fine against the heat.
Did I miss anything? : )
S14aMike
Yeah, one thing, carbon fiber is very expensive, so where can I get a stock looking fiber glass hood?
S14aMike
I guess Ill just have to shell out the money and get a carbon fiber hood. Who makes a good one?
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
i doubt there is that much difference from company to company. there are alot of places out there on the web that make them. just google search or sumthin.
Daunttless
There are a lot of differences in the quality of materials, try to buy from a place that specializes in either fiberglass or carbon fiber. If you get ****ty materials its a waste of all the money you spend. There IS a big difference in this market...
MasterMan
Car: nothing running at the moment city buses "uck here
here is a site with clear hoods.. kinda cool if your gonna do SR swap or somthing.. show off the insides :) (tho some of u might think its rice.. i havent seen anyone with it so i think its kinda cool)
http://eurohoods.sureshopping.com/default.asp
Spectre
Daunttless wrote:Did I miss anything? : )
Nope. Thanks for clarifying the heat thing.
Megaseth
Car: 2002 Pathfinder SE
about the painting issue. CF hoods and other pieces can be painted, like the other guy said with a little scuffing, but why paint it. if you're gonna spend the $400-500 on one, leave it CF looking. or, i was watching some Rice show on Speed channel and i saw an Eclipse with a CF hood that he painted by spraying a clear candy red in the air over and let fall down and then a few clear coats. made the hood red tented. looked real nice.
iwantanr34
Car: dori
im looking at carbon fiber hoods too, trying to free up some weight, and i came to the conclusion that if i get one, i might as well do it right... i saw one with a giant negative hood scoop, (you know the kind that suck the heat out of your engine bay) for like $450... and one thing that people do to "de-rice" cf hoods is to paint part of it... there is an Si on my block that just left the center unpainted so you could still see it was carbon fiber underneath and covered it in clear coat so it would be safe to wash... looks really good too.
Megaseth
Thats a good idea. i didnt think about just painting some of it and leaving a little bit of the CF showing. this guy i know has a F&tF blitz style kit on his Eclipse. it looks fast, but it is only a stock GS. he has a small piece on the front that is CF, well looks CF ish and you can see where it has a bad paint job on it, like it was painted on.
UncleBen
Daunttless wrote:There are a lot of differences in the quality of materials, try to buy from a place that specializes in either fiberglass or carbon fiber. If you get ****ty materials its a waste of all the money you spend. There IS a big difference in this market...
well sorrrrrrrrrrrrrrry. :)
