FI to triple carb
A home for 1983–1989 300ZX owners!
needmydatsun
Car: 1978 datsun 280z
if i switch from stock fuel injection to a 3 carb setup on a '78 L28e will i get more power, mpg, or torque? does anybody know?
Modified by needmydatsun at 3:02 AM 3/3/2007
Stealth-Z
Car: 1991 300ZX
One thing I can say is you will have additional headaches keeping them tuned. Modifying the fuel injection is a better way to go for what you are looking for. It took me a while to get used to the fuel injection system on my 78 daily driver. It is not really all that complicated. There are lots of options out there.Just my opinion from dealing with 44mm and 50mm triple Solex's on my old 73 Fairlady Z with an L28.
Boosted 70z
Car: 70 datsun 240z
Usually carbs only work better than fule injection during wot, so I doubt you'd see much more power from carbs, and you definately won't get better gas milage.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
a well tuned set of tripples, of the proper size and jetting will give you more power the stock injection system sucks
needmydatsun
thanks guys, i'll see what i can do with fuel injection. do you guys know if fuel injectors from other z cars(300zx) are interchangeable? im guessing i would have to get an ecu upgrade but im not sure
Modified by needmydatsun at 12:45 PM 3/7/2007
evildky
06 Nissan 350Z GT
the stock ECU isn't upgradable, if you plan to keep the injectiona dn modify the car either a Z31 ecu swap or stand alone (like megasquirt) is the only way to get it right,a nd the Z31 uses the barbed fuel injectors as well but I think they are the same size as the turbo L28 injectors
Return to “300ZX (Z31) Forum”
