Sorry Wiggler didn't even see the email - just checked again, didn't receive...
paranoidjack (at) comcast.net?
Anyway,
I took a close look at all 3 pics. Though it appears you have everything, there's always something hiding. Give it a smack from the side with a hammer (it's aluminum, be careful, not hard enough to break your arm if you hit it for example) and see if it "breaks" from the gaskets. The gaskets are thick rubber and as I recall had *zero* bind, so it sounds to me like something is still connected. Does it lift up in the front or back more? Left or right?
Double check all bolts, there's always one hiding, and pay close attention to behind the plenum. Sounds to me like you're binding a rubber line, coolant or vacuum. Easy to do. You may have to remove the terminal end of one of the vacuum lines going to the MAP/BAR sensor (the one on the bracket mounted underneath). I'd STRONG suggest LEAVING it connected under the plenum runners, and disconnecting the other end, not the one at the bracket under the plenum.
Oh, and those plastic things are called pintle caps. Yeah, it stinks when they break. Not the end of the world but they (I think) are designed to give a cleaner and more consistent spray, thus also reducing the chance for seepage around injector orings.
Had the same problem:
http://www.youtube.com/watch?v=plbvv77tKHk
PS those fuel lines were a b**** huh?
