0ptimus prime »
https://forums.nicoclub.com/0ptimus-prime-u33760.html
Sat Nov 19, 2005 6:07 pm
I SEARCHED!! ... alright now that that is out of the way...
I'm in the middle of an SR20 redtop swap in to a 1991 240sx. I have the entire front clip so there shouldn't be anything I'm missing. The car is already running but i have minor issues to work out.
My questions are as follows:
- I wired the SR/KA harness according to the Heavythrottle FAQ. On the Stock KA harness, there are 2 plugs by the passenger side headlight, on the SR harness, there are three. I cut the 3 plugs off the SR harness, and wired them to the 2 KA plugs. I did this directly according to the FAQ. I am left with 6 wires that weren't mentioned in the FAQ, what are these for, and should i leave them disconnected?
- I purchased the entire front clip, so i used the JDM s13 radiator. My question is: Why wasn't there a fan on the radiator? The stock 240sx fan doesn't seem to fit on the JDM fan shroud/radiator. And am i supposed to use the JDM fan shroud? I just want to verify how to properly set up this cooling system so i don't over heat. Am i supposed to just leave the jdm fan shroud off and buy an aftermarket fan or what?
- Last question: I wired the SR20 ECU harness to the stock 240sx dash harness. Again, i did this according to the heavy throttle FAQ and there are around 6 wires left over. According to them, this is for the check engine light? Just verifying.
Put your heads together!!
