Few simple questions with PICTURES.
DEEPfrom1
Car: 94 vert
Hey everyone whats up? I have two questions, I am sure someone can answer them super easy.
First question: Where does this coolant port go to?
Second question: Do these motor mounts look strange to you? I feel that the drivers side is way to short, I am probably wrong though.
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
the coolant port is for a heater hose and should point back towards the trans. idk about the mounts, the ka sits with a bit of a tilt.
DEEPfrom1
Car: 94 vert
Thanks, anyone else have a say on the mounts?
neverlift
try turning the motor to see if its level how it would sit c*** eyed in the chassis.
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
Motor mounts look fine. Turn the motor till the bottom of the oil pan is level with the ground, this is how the engine naturally sits in the car. As long as the mounts look relatively even side to side as judged by the eye, you should be good. Don't really see how they could be messed up anyway, but its for your own peace of mind I suppose.
