Few Rattling Questions. Sunroof in tilt and Bose Door Panel
ikalinin
Car: 2018 Infiniti QX60 Deluxe Tech
2018 Nissan Rogue SL
Hey all,
question for those that hate rattling noises. I can't stand it when something rattles.
Pano Sunroof in tilt open:
Rattling noise toward the front. when you go over big bumps, or if you tap the edge of where the front of pano roof is, it makes a rattle.
what can that be and how can i fix it?
Driver Door w/ Bose Audio:
During bass heavy songs, the front door rattles w/ the low freq beat. none of the other speakers/doors make this noise.
suggestions?
thank you all in advance. :)
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The rattle in the sunroof could be a lot of things, but the rattle in the door is likely from drumming in the outer sheet metal. You can usually shut that up by removing the inside door panel and tucking some foam blocks in between the tubular longitudinal support and the outside shell.
Return to “Rogue Forum”
