I just had some 16x8 Vision Soft 8s installed on the 1999 QX4. I was shocked when the tire/wheel guys said the center caps (push-through style) won't fit on these on the QX4. Is there any way to make them fit? 1/4" spacers recommended? I know it is no big deal and assume it's common because I see them missing from QX4s and Pathfinders in some pics but they sold me the center caps and I'm frustrated since they waited until they sold me the wheel/tire pkg and finished install before they told me.
Front/Rear Coil Springs:
Perhaps I missed something but will 1999 Pathy springs (Moog maybe) fit on the front/rear of 1999 QX4? Seems like they would be direct fit but survey says XXXX every time I check comparability on order forms. QX4 coil is .50 and Pathy coil is .52 so if that's it then they'd probably be stiffer which is what I want. I was going to install Pathy springs (refresher to old non-sagging coil springs but they also feel softer than I want) and 1" strut/rear coil lift while I'm in there (spacers).
Thanks fellas.
