themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Thu Mar 04, 2004 12:28 pm
no you won't. the hubs don't interchange unless you have an S14 in which case they might. I know for a fact the S13 will not accept Skyline hubs but I have never done the S14 so it's worth a try. The calipers will bolt to the hub, you may have play with washers to get it centered of the rotor but that's it. Get the master cylinder off the donor clip. You will need a minimum 1" master. It has "BM44" cast into the master cylinder housing. If you have ABS you will likely need a 1 1/16" master, "BM50"
