480sx »
https://forums.nicoclub.com/480sx-u50548.html
Mon Jun 02, 2008 7:02 pm
Its really not that bad, however it can be dangerous. You will get backfires, and stumbling when pushing in the clutch from boost. The car will want to stall if your getting into it, then push in the clutch and let it idle down. Light application of throttle will keep it alive.
This can give you problem in a panic stop situation when your in boost. Brake, stall, no break booster or PS, crash.
