evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu May 24, 2007 7:41 am
when you buy a used trans, it does not come with the pela, addy, cluthc booster, hoses, flywheel, pressure plate, or disk, also I think it requires a different driveshaft, you also need to either swap the harness and ecu or disable the neautral saftey swithc,a nd wire in a clutch saftey switc, if at all possible hold out for the 5 speed, the swap will end up costing you much more than just buying the car you want and thats without labor!
