motoman399 wrote:1. yes you can remove the seam sealer. its there just to keep moister out/rust.
2. no the welding isnt going to kill you. just make sure you put the ground clamp on the car and not your foot. lol
3. you can weld everything that is a seam. so like where all the panels meet.
4. its actually called stitch welding. and i think you should practice a lot before you start. and start on the inside so when you get to the visible stuff it looks good. and dont do a continuous bead. you can either do tacks every 3/4-1" or you can do small beads 1/2"-1" every 2-3". i would do the tacks though.
5. practice practice PRACTICE!
1. sick im going to be removing that junk tommorrow then along with the rest of the sound deadening
2.haha ill be very careful to get the ground close to the area im welding and not my foot.
3.ill be hunting for every possible thing i can weld haha the chasis is all creaky and nasty sounding so id like it to just be solid
4.stitch welding yeah that sounds more right than tach welding haha. and i figured my car would be the practice since its already ugly as hell and i just want it functional. ill probably go with very small beads every inch
p.s. im assuming the .030 2 lb will be enough of a spool to do the whole thing (comes with the welder and id like to use that before i spring for the 10 lbs haha)
p.p.s. suggestions on how to get the remaining crappy sound deadening residue off of the metal?? its annoying cause the dry ice got off the majority but there is still residual crap around like the wheel wells and stuff...how do i get that crap off!!
thx
