aez987 »
https://forums.nicoclub.com/aez987-u27583.html
Wed Nov 09, 2005 11:24 am
Hello,
I have a 1997 Q45t. I have a few minor issues that I need assistance with:
1.) The driver's side cat converter's heat shield dropped off partially. There was a wire (looked like a ground wire) attached to the heat shield. I completely removed the heat shield. Are there any detrimental effects from removing the heat shield? What was the wire used for?
2.) The car has had a persistent on-and-off hesitation issue for the last 6,000 miles. The car tends to stutter or move very slowly at very irregular times. It doesn't appear to be temperature related, or engine load related - it's just happens at random. I always use premium fuel. I've changed the air filter. Anyone experience this issue?
3.) The wing mounted LED third brake light has a few dim bulbs. The dealer wants MAJOR money to fix. It doesn't appear that it's a simple bulb replacement. Can anyone steer me in the right direction to fix this?
4.) Finally, how do I remove the fog (driving) light lens? I know how to change the bulbs, since I've done that numerous times, but I want to get inside the actual housing. Amazingly, I've been under the car for hours trying to figure out how to remove the lens, but it won't budge. Any help on this one?
Thanks in advance for your assistance.
