Pumaking wrote:is there any advantages to using high or low impedence. Would it be worth the extra for the high impendence or regardless of each one both will perform the same just high impedence will take more work to function properly. Also exactly what is required to get the high impedence to function.
Hope this helps...
"Most OE applications use high impedance (12-16 ohm) injectors due to their lower cost and the ability to use saturated drivers in the COMPUTER. Lower impedance injectors (2-4 ohms) respond quicker (shorter rise time) but necessitate the use of peak and hold drivers which are not only more complicated but more costly to manufacture. By design, a saturated driver will keep current draw constant during its whole duty cycle. Conversely a peak and hold driver will initially surge the current up and then step it down to a lower value and maintain that value throughout the event. If a peak and hold injector or driver is rated at 4/1 amps that translates as 4 amps to open the injector and 1 amp to keep it opened. Historically, tests have proven that a low impedance injector will have a rise time of just below 1.5 MS, while a high impedance unit can approach 2 MS."
I got that off a "How EFI Works" site.
In a nutshell, low impedance are better in a high performance situation due to the quicker response time.
