I am building a Rb25det for my RHD Vert and I bought a RB25 longblock that was pulled out of a skyline because the owner wanted to upgrade to a RB26dett. I am doing a full "stock" rebuild on the motor and also buying parts for it. I figure is I was going to spend 2500 on a rb25det, why dont i buy this motor for 100 dollars from a friend and build it from scratch because i still have to buy harness and mounts and driveshaft and also dont know how good the motor is. anyways heres some info i need and please just help instead of saying "search"
1. What Block Do I Have? (pics below)
2. Does anyone make a premade harness for s13 (meaning i dont supply them with anything.)
3. I have a RB20det Transmission but when the car is warm it will not go into second gear when you drive it but you can turn the car off and it will go into gear or when the car is cold and you drive it it will go into gear, Why?
4.What ecu's can i use for my setup?
5. Whats the 75T on the engine block? (pics below)
6. What missing in the hole between the freeze plugs?
