D1 guy wrote:Im wondering what my sr s14 should read on the following gauges...
oil temp-oil pressure-fuel pressure-water temp- wideband (with good tuning)-
any help would be great. Thanks in advance. I just want to make sure everything is running good.
these arent exact but it should help you out.
oil temp - around 200 - 220 Foil pressure - 10-20 psi at idle, shouldnt go higher than 75 psi at higher rpms. Dont be alarmed if the gauge reads high when you start the car thats normal.fuel pressure - 43 psi with the vacuum line disconnected (Stock)water temp - around 185- 200 FWideband: 14.7:1 or so cruising off boost11.3-12:1 at WOT on boost12-13:1 on boost part throttle19.5 ish on deceleration
