pancito »
https://forums.nicoclub.com/pancito-u529.html
Sat Aug 10, 2002 4:38 am
There are a few problems with the car, it was used and has 66k Miles, here are the symptoms, ca you guys tell me if it's normal, easy fix or a common problem, and where can i check about recalls (is there any?)
1. Hood doesn't want to stay down, after it click's locked, if i pull with enough force (not that much) it will pop out again, it poped out today driving, and i don't want it to happen at high speeds.
2.- The Sunroof rattles while in the OPEN position, is like is very loose in the back part, if i close it just a little bit it will be less.
3.- Where does the stock wiring for the back speakers go?
4.- What books do you guys recommend (chiltons, etc.) for fixes
5.- wich is the fattest tire + rim i can put in the back in 16" or 17" (What do you guys recommend)
6.- How do i know if the struts (or shocks?) are still ok or need changing.
7.- What plugs and plug wires do i use NGK but what model?
I have a lot more, i have read and read here and came up with a few answers but still i have a lot more, and sorry for my english and if i posted in the wrong forum.
