spitz7985 »
https://forums.nicoclub.com/spitz7985-u2738.html
Sun Jun 27, 2004 1:42 pm
Whoops, I meant the shims that the cam lobes push on.
Well, I'm running without a thermo right now, took it out last night after work. Only side effect I've seen is the obvious, really slow to heat up. Not so bad though, still heats up faster then it does in winter. I'll get one in there before it gets cold outside.
Thanks for you reply, but I was looking for something a little more detailed, someone who has changed a bulb in there already so I know what to expect. I'm sure I could have figured that out.
