i have a safc, but it didnt need any tuning, 11.5s at wot and 15s crusing...Carl H wrote:twin z32 mafs and no tune?
ah indeed. definitely something to look into.arauz wrote:Have you resolved any of the oil issues with the motor?
not yet, this winter when i go single/ fuel/ cams, im going to do the crank collar and new bearings then.arauz wrote:Have you resolved any of the oil issues with the motor?
Is that true? What about doing the combination of all three (autox, drifting, drag)? I guess I should find out before installing my lightweight flywheel or not - I'll also be getting a aluminum driveshaft....I think.HxC_Nismo wrote:i would of kept the stock flywheel since it looks like your only going to drag race cause light weight flywheels are design more for the autocross/drift. other then that if you cut a 1.8 60ft you should be in the low twelves but dont expect to hit anything higher then 114-115mph on that setup. i ran the stock twins for a while and never trapped higher then 114mph with the stock twins @15psi and a gizzmo launch interface. other then that not bad man.
i like them, they are smooth but firm at the same time... and the trans mount bolted right up to the z trans no problem.nyc240sx wrote:thats cool thanks i just got back from getting my flywheel resurfaced now i need to order my clutch iam going towards the act clutch...After that i'll be buying the driveshaft i wish i can buy everything now and get this bish started already but i dont wanna rush things...How you like those mckinney mounts do they feel solid when your driving? I was thinking that the mckinney transmission mount wont line up since its not the rb25 transmission did you have to modify that
but for now im sure its fine on stock twins... this winter will be expensive lol
yea, im thinking a t71gtq right now.... i dont know, going to look into it more when the time comesBoostFab wrote:that's very nice sleeper.... only a hickup away from 11's time for a gt35 LOL
