navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Sun Jul 04, 2004 3:00 pm
damnit i posted but its not showing up.
the brake light: triggered by the switch and the level at the MC. if your pads are low, then the fluid is low, change the pads and dont add more fluid, if you do it will overflow when you push the caliper pistons back in, and that is bad
my needle will go past E too, does it give you an accurate fuel measurement?
