ThisIsSparTTa »
https://forums.nicoclub.com/thisisspartta-u210180.html
Sun Jul 13, 2014 6:49 am
I'd try to keep your threads focused on a single topic or related topics. Otherwise it becomes very difficult to address a bunch of questions at once. No problem asking "easy" questions though if you've done some research before.
If it's coming out of the front of the engine, sounds like water pump or thermostat. If you're not sure when 120k was done, it may be time to bite the bullet. Otherwise, 3rd party OEM water pumps are known to fail in very short time, usually around a year, could be that. It could also be the coolant bypass hard pipes didn't get RTV'd back to the block correctly, or the coolant bypass rubber lines are leaking (go silicone!).
The electric fan on the front of the engine is an aux fan. Your main cooling should come from the fan on the front of the engine. Fan clutches commonly fail. Read up on how to test them.
