240z4u wrote:Wow.
What pump are you running?
Looks great man, you should be proud of that one. Did they nitpick you during tech? They really went over my car when I went last time.
Evan
Yea I'm really happy about the 131mph, takes some serious power to do that. Can't wait to give some ET Streets a shot!
Yea GLD got a lot more strict after some of the big name drag racers got hurt/died. For me they weren't too bad, they looked at my helmet and made me pop the hood. I'm not really sure what they were looking for though, since I'd bet they really didn't know what they were looking at.
As for the pump. Right now I am running dual intank walbros with a -6 feed. Over the winter I will switch over to either dual bosch intank, or some reliable external pump with a little bigger feed. Probably also step up to 850s or 1000cc injectors (up from the 750s I have now).
Either pump setup should easily outflow the walbro setup under high pressure. I just want to make sure that it is reliable and reasonably quiet since the car is very much a street car.
Yellow4g63 wrote:10" wide rims in the rear?
9.5" wide. Tires are 285/35/18 Nitto 555Rs. They are great on treadwear and still have decent sidewalls on them for handling. Great tires for the street, but they just can't handle the power at the track.
I'm just going to get a set of wide 15s and get a set of ET Streets that I can use for fun weekends on the street and at the drag strip. Still a little too nervous to move to full blown slicks.
